| | | Forums66 Topics128,271 Posts1,058,417 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2000 Posts: 4 Junior Member | | Junior Member Joined: Oct 2000 Posts: 4 | TPYLE, I'm kind of new to the forum but I have a couple of Burbs and a panel. I think in (late?)1952 GM stopped using solid yellow pine planks and began using marine plywood. Yellow pine is a hard durable wood. If you want to keep it original get the ply. Also they shortened the metal strips a couple inches. Measure your 49s and compare to the 53s. Mar-k probably can tell you more.
It's time for a road trip!!!
