| | | Forums66 Topics128,034 Posts1,055,536 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I don't think there is a brake line running under the raditor on a stock 1950 Chev or GMC.
I'm absolutely certain there is not on a '54 or '55 1st.
On the stock truck there are two lines coming off the master cylinder. One of them goes only to the left front. The other crosses under the bellhousing to a tee fitting. One line goes forward from the tee for the right front, the other goes to the rear where it terminates in a flexible line that goes to the rear axle.
Are you sure you have a brake line running under the radiator?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
