| | | Forums66 Topics128,020 Posts1,055,345 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Larry,
I think the adjustment Fred is speaking of is the bottom bearing preload for the worm gear. If this were the cause of your problem, it might be noticeable in the steering wheel itself. A gross misadjustment here would force the whole shaft up and down...trying to shove it into your chest or pull it away from you. As you turn the wheel back and forth, you would see any gap between the wheel and turnsignal cup get larger, or diminish. I think this is how it works.
Stuart | | |
