Kyle,
With a clean tank and clean fuel, any available mechanical pump should be fine and work for years. A electric unit would require additional wiring, some roll over safety feature, and would be basically much more mechanically complicated than a simple stock pump.
My guess is that with a new mechanical pump and good clean fuel, your problems would over. Cleaning or replacing the fuel tank would be the first step to solve your dilemma.
Stuart
