| | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#24005 10/24/2004 10:47 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Sounds a little high. First thing to do is check your water temp. With the engine warm and water flowing through the radiator (thermostat open) put a thermometer in the water. I use a meat thermometer that I know is fairly accurate. It should be the same as the gauge. If it's not the same, you will know how far the gauge is off.
If it is the same, pull the thermostat and check the opening temp on it.
Fred 52 3600 69 C-10
