| | | Forums66 Topics128,090 Posts1,056,024 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | This is a common happening. If area is just around the valve stem hole and the rest is solid you can clean the rust off, weld the valve stem hole and any other holes up (might have to gas weld because metal is usually very thin), and coat with an epoxy like JB Weld. This will let you use tubeless tires. Lastly, drill a new valve stem hole 180 degrees from the old hole in nice virgin metal.
Evan
