| | | Forums66 Topics128,069 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | The only thing the tie rods control on a drag link solid axle steering is the toe-in. The drag link is not adjustable, so the only only way to center the steering wheel on this setup is to remove the steering wheel and place it as close to center as possible on the splines with the pitman arm centered. The steering wheel only steers the driver's side front wheel and the tie rod just allows the othe wheel to follow. Usually people refuse to believe this, but it is true. | | |
