2 members (Gdads51, Flint48),
165
2
Mod | | | Forums66 Topics128,088 Posts1,055,995 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23843 03/15/2002 3:12 AM | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | Sounds like either stuck valves or bad timing. Those Pontiacs had nylon teeth on the cam gear, and those teeth got brittle and broke off after a while. First thing I'd do is take the distributor cap off and have someone crank the engine while I watch the rotor. If the rotor is jerky, then I'd suspect the cam gear. Shouldn't be too much trouble to pull the timing cover off and take a look to confirm it. | | |
