Go to http://www.700r4.com
Click on "calculate speedometer" and all you need is your tire height(diameter) and rear end ratio. It will give you the needed drive gear(on the tailshaft) and the gear the cable plugs into. These gears are plastic, relatively cheap and available at any GM dealer.
Evan
