2 members (DaveV, Napco Man),
99
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,260 Posts1,058,343 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23688 03/06/2005 2:56 AM | Joined: Feb 2004 Posts: 29,944 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,944 | What year is the 235? If there's a big oil gallery running between the lifters, hydraulics can be run, but the cam and lifters MUST match. Hydraulic cams have a different profile, and completely different acceleration ramps than solid-lifter cams. If you're buying a new cam it's absolutely imperative to run new lifters with it. NEVER put used lifters on a new cam, and ALWAYS run the correct lifter for the cam. Solids and hydraulics cannot be swapped! Jerry
