0 members (),
133
Mod | | | Forums66 Topics128,283 Posts1,058,505 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | My ’41 had them on both sides. Initially I thought they were 1 inch thick. When all of the grease, caked oil, and road gravel was removed they turned out to be about 16 ga. sheet metal. They were FUBAR being so bent and rotted away they went into the trash.
At the back the pans were mounted to brackets extending inward from the frame at the point where the bellhousing starts. (On the drivers side the clutch return spring also is attached to this bracket.) At the front there were holes directly in the front engine crossmamber. | | | |
Entire Thread
Engine side splash pans, were there any in 41-46?
| 46 Panel | 06/20/2007 4:06 AM |
Re: Engine side splash pans, were there any in 41-46?
| down2sea | 06/20/2007 4:18 AM |
| Joe McNeel | 06/20/2007 6:52 AM |
| Denny Graham | 06/20/2007 12:26 PM |
| Kip's41 | 06/20/2007 7:00 PM |
| 46 Panel | 06/21/2007 1:34 PM |
| Grigg | 06/21/2007 4:34 PM |
| Jed | 06/21/2007 11:09 PM |
| rustednuts | 06/21/2007 11:31 PM |
| Delux | 06/21/2007 11:45 PM |
| down2sea | 06/22/2007 2:18 AM | |
