There is a least 1 in El Reno, Oklahoma being hot rodded. Welcome to the "Bolt". You will find several Oklahoma Connections if you hang around long enough. I bought a '52 from the same salvage yard in Stillwater. All the AD's there seemed to have had the front/rear suspensions cut off. If you want to go back original let me know as I have the suspension/axle parts to put it back.
Martin
‘65 Chevy Biscayne (Emily)
