I could use some advise, I need the rear brake backing plates off a 53 so I can install the original brake and e-brake system. I currently have all the original brake hardware includung the drums but I have a newer rear end with a different rear brake system.
The good news is I have found the backing plates I need, the bad news is they are rivited into the axle housing. What is the best way to get the rivits out? Where this truck is located I have no air or power avaible. Any idea's?
