on the scout II aprox 43" bolt to bolt on front, and aprox 55" on rear (if these numbers are close, and you want me to measure them closer let me know)
Brian Kemp
[email protected]
note: scout II's had the axle mounted above the springs, just so you know.
Sometimes, David beats Goliath. Nobody talks, however, about how many little guys Goliath already beat into the ground. . .
