| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23497 08/08/2003 4:52 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | If you overtighten the oil pan you are changing it's shape. It doesn't want to be very tight.
I glued the cork gaskets on the oilpan with a semi permanent gasket sealer and let that dry. Then I applied a healthy amount of regular gasket sealer on the top and installed it. Just tighten careful.
54 3100 with 235 62 flatbed dump C60 with 261
