I have been all over this site and others and don't seem to be able to find the answers to these questions.
1. what is the width of the inside of the 1/2 ton pick up bed?
2. What type of rear end housing doe they use?
3. What is the rear end ratio?
4. Can you change the ring and pinion and what are the available ratios?
