8 members (klhansen, Shade Baby, Shaffer's1950, JW51, Cosmo, Oswald, 2 invisible),
57
Mod | | | Forums66 Topics128,075 Posts1,055,919 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23326 05/21/2005 2:18 AM | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Sheet metal covers develop dimples at the bolt holes, which compress the gasket in one small area, and leaves long sections without enough tension. Cast aluminum won't distort that way. Chevy finally got it right with their late-model engines, with four bolts down the middle like the old Studebaker, and a captive O-ring in a groove, instead of a gasket. Unfortunately, you'd have to change cylinder heads to take advantage of the new design! I'm not even sure the late heads will fit the old block, but I don't think so! Jerry
