Hi Kyle,
No I don't have a factory assembly manual. I probably should pick one up. You may be right about having some wrong parts,like the backing plates maybe, that would make sense. Maybe you can answer a question for me. Do you know how the bottom screws on the bezels are mounted to your grill? I don't see any mounting points on mine unless there's supposed to be a speednut type fastener on the grill.
Joe
