I need a little help here...... My '84 1/2 ton Suburban (2 wheel drive) is sqeaking ( both rear wheels) while moving at idle. I have replaced the shoes and had the drums turned.
I have rechecked myself. No, I don't have the shoes backward, the ebrake cable is free, hardware is on correctly.
It will stop sqeaking if I just lightly apply a little bit of pedal (still moving though). I can do not see any evidence of the edge of the shoe rubbing on the drum. What's up??????
I have had the drums turned before and was told this would be the last time. That they were getting thin. The shoes I bought are OEM type NOT semi metalic.
Thanks in advance for any ideas,
Stingray
