I have just fixed the crank mechanism and the window goes open and closed but it leaves air spaces at the lower corners. The strap that connects the two halves together was missing so I made one. I dont think I made it beefy enough.
Can someome give me the dinensions of the original?
How long, how thick, how tall and if you can, the angle its bent at.
Is there only one on the inside?
Top and bottom?
thanks as allways.
