it can be done, but you'll need to fiddle the hood hinges where they bolt to the firewall because the bolt holes are slightly different, and the frame has to have about 2" cut off the front and the bumper mount holes redrilled - I can supply more detail if you find yourself there - this truck is on a 58 frame
