0 members (),
108
2
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23068 05/12/2005 5:59 AM | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Check and see if the collar that has the slot for the hold down bolt is all the way to the top of the machined area. If it somehow got clamped lower than it should be then the shaft might not be engaging the pump. You can loosen the clamp bolt with a flat blade screwdriver with the distributor in place, hold light downward pressure and roll the engine over. If not all the way down it'll drop when shaft aligns with pump.Way to easy but good luck.
Evan
