There was an incident like this with one of the most experienced members of the VCCA. It turned out that the distributor was not seated in the oil pump and the oil pump was not being driven.
Did you feel a lot of drag in the drill when you were running the pump? Also, what was the pressure reading when you were driving the pump?
