What do you need? Rugo and I disassembled his tonight. Pulled axles, torque tube and third member are sitting under my new bench
Banjo assembly is sitting on the floor with backing plates. Cover is sitting in the solvent tank. Getting ready to steam clean it, and put new seals in the axle housing. It is all open and pictures would be easy at this point.
