Jim,i had this problem on my 66.I went around seeral times and still had to double pump.Itryed gravity bleeding,no luck. Iput speedy bleedrs on,went around a couple more times and still 2pumps.My neighbor came over and used a vice grip to pinch shut the ruber lines one at a time. When he pinched off the third one i had full solid pedal.That worked great for isolaleing the problem.Turned out that the spring on one wheel that holds the star adjuster in place was missing and alowed it to turn way out of ajustment.Ron
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are... My progress pics
