Well the bushings do have the groove on the out side. The shop manual says "make sure the holes are lined up" So I am unsure as to proceed or get another set of bushings or what. Can I buy another set of large bushings? One more thing, how do you install the caps? I did not remove any from the original pins except one on the passenger side. Thanks for the help atomarc!
