I recently bought a fedhill flare tool and their copper/nickle brake line. Their line will not corrode like SS but you can bend it with your fingers. It is rated higher in burst strength than steel line. Their flare tool is incredible. In a matter of seconds you have a perfect flare every time. Their line is approximately $60 for 25 feet and the flare tool with two die set sizes is about $400. I know thats not cheap but you could always share with a friend or two. Their product is so stinking easy to use I thought i would share.... If the shop was on fire i might save the flare tool first smile - kyle
http://fedhillusa.com/
I'm a 6 volt guy in a 12 volt world
