I've never seen the tank out of a 36. My 38 has a "U" shaped baffle in it to keep the gas from sloshing around & making the gas gauge dance. The sending unit is located inside the baffled area. The only cork I've seen is on the end of the sending unit arm. Someone else will have to help you with that one. Welcome to the 'bolt Shane.
