You guys are the best! Sort of have a wide range of suggestions. I will look at the condition of the front end first and go from there. I will have to modify the hydralic clutch if I do anything with the master cylinder. Any easy fixes? If I swap cradles, guess I will have to fabricate new engine mounts as the 6 mounts on the front of the cradle.
Thanks
