13 members (greenie-reddy, Gdads51, 1955 1 Series, KEVINSKI, Greg_H, Bill Hanlon, Otto Skorzeny, klhansen, Ponchogl, cmayna, Peggy M, 2 invisible),
105
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#22359 02/15/2004 4:26 PM | Joined: May 2001 Posts: 9 Junior Member | | Junior Member Joined: May 2001 Posts: 9 | DOT3 (&4) are glycol-based, while DOT5 is silicone-based.
In theory, DOT5 is superior to anything else as it has a higher boiling point and doesn't attract moisture, but for the life of me I have never had luck with the stuff. It seems to hold air which leads to spongy brakes and your system has to be totally rid of the old fluid as the two aren't compatible.
Valvoline Synpower makes a DOT4 that I can recommend. I wasn't satisfied with the brake performance in my '51, so I flushed out the DOT5 and replaced it with the Synpower DOT4 and all my problems went away. | | |
