| | | Forums66 Topics128,042 Posts1,055,520 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | [QUOTE] [The guage works with the sending unit out of the tank and goes through the full sweep, but when the sending unit is in the tank, it reads empty, regardless of the fuel level.]
If the needle moves when you move the arm back and forth then the sending unit is functioning. Sounds to me like you have a hole in the float. Gently remove the float from the arm and see if it bubbles when you hold it under water. You can buy the float separately.
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
