7 members (Shaffer's1950, David Bush, Hotrod Lincoln, JW51, Gdads51, Gray_Ghost, Gib70),
107
0
Mod | | | Forums66 Topics128,051 Posts1,055,735 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Usually isn't a big deal if you can find someone with a big enough break. Often the roll is just a piece of pipe welded on top of the bedside. I don't remember what the stake pockets look like on thsoe trucks but if it's square that can be folded up aswell. If not I believe you can buy those separate and just spot weld them on.
Good Luck. | | |
