| | | Forums66 Topics128,037 Posts1,055,465 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | Randy B., I think you need to mention to ALWAYS refer to the specific service manual for their year and type of truck. There are MANY different configurations that are year/size/type specific. For example 1946 1/2 tons had press in bushings that needed to be honed to fit the kingpin on all size trucks. While 1947-54 (maybe others) 1/2 tons had "floating bushings" that didn't need to be honed (and did not have the benefit of a locking ring but the dust cap had to be staked). On 3/4 tons and above the bushings had to be honed to fit. The groove on the outside of the bushings is only on the floating bushings. The use of a thrust washer versus a thrust bearing differs. In 1946 a thrust bearing was used on all size trucks. 47-54 only used a thrust bearing on the 3100 - 4400 trucks. And these are just a few of the differences. I hope others will tell you about the differences on their year/size trucks. As always, somebody will correct me if I am wrong. Good luck! P.S. I think the Tech Tip was a REALLY good job!!
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
