You can purchase the early bell houseing I believe 60-62 for a V-8 and it will have the original hydraulic mount on the right side.It would be a direct bolt up if you can find the lines and the master cylinder /clutch cylinder.I went the other way with mine .I didn't like the hydraulic .
