Why do you need more stud length? Are you thinking that you need long wheel lugs because this really isn't logical. You only need longer studs if the wheel nut combination puts your lug nuts past the end of the thread. What you probably want is a lug nut that has the correct face angle and doesn't bottom out.
I don't think that you will find studs of a different diameter that fit your hub.
