8 members (Wally / Montana, Gray_Ghost, Bill Hanlon, warlock, Wayne67vert, dt235sd, TexasA&M48Truck, 1 invisible),
58
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,052 Posts1,055,724 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#21744 04/15/2003 10:28 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | There should be a filter in the big fitting where the fuel line goes into the carb. Make sure you put the filter in the correct way(spring goes in first then the filter --hole end of the filter out). The large fitting also has very fine threads and can be damaged very easily when trying to thread it back into the carb so make sure it goes in straight and turns easy.
There is enough good in the worst of us and enough bad in the best of us that it does not behoove any of us to criticize the rest of us. - - Be yourself. If you are ever lost, It will be much easier to find yourself if you know who you are!
