| | | Forums66 Topics128,056 Posts1,055,804 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#21737 02/26/2004 3:29 PM | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | What type of rear ends do you have? Are they identical except for the axle tube attachments? I don't think the axle tubes come out easy and you are probably better off removing any necessary brackets and welding on to your new axle. I just put a 14-bolt in my '55 out of an '89 3/4 ton and it only took about an hour with a cutoff wheel, grinder and air chisel to remove some spring perches and a few other attachments. The fit-up and welding took a lot longer. Pinion angle was the key. | | |
