Hi Joe, it was nice meeting you at the Ballpark swap meet.
I bought both the peal and stick and insulation (the insulator) from JC Whitney. They both came in sheets of approximately 3 by 5. I put them under my rubber mat in my 55 2nd. The only problem I had was that I had to cut the insulation over the hump in the middle of the floor so the gas peddle had enough room to work correctly.
