| | | Forums66 Topics128,050 Posts1,055,670 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | As most folks would say depends on time and money.
Do you want it to look stock? Replace the rear end and put in a 235. Do a search and you'll find lots of info on both swaps. This can be done with minimal investements.
Want a big engine and have lots of money? Replace the entire frame and running gear. You can buy a rolling frame from a number of sources, check out Progressive.
Good luck. Do lots of research here before you go too deep. | | |
