7 members (Rusted Nut, BC59, Phak1, Robert Crandall, Gray_Ghost, Southerntruck, 2-Ton),
137
3
Mod | | | Forums66 Topics128,128 Posts1,056,686 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#21415 10/04/2004 6:03 PM | Joined: Feb 2004 Posts: 29,837 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,837 | There shouldn't be a problem with using that lube, especially since it stays at the 85 thickness all the time. It just lubricates like a 140 whern it's hot. That's the same thing a 10W30 oil does. It doesn't physically thicken as it heats up, it just hangs on and lubricates like a thicker viscosity oil when the engine is up to normal temperature. Thw "W" in the designation means "Winter", indicating the flow rate is checked at 0 degrees Farinheit. Your 85W140 will flow like a SAE 85 oil all the time, and lubricate like a SAE 140 at high temperature. Best of both worlds! Jerry
