| | | Forums66 Topics128,139 Posts1,056,448 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i am about to take the 3104 in for painting. i need to replace the bolts on my running boards. they use a somewhat special bolt available, kinda like a carraige bolt w/ a flat head ??? from vendors. ok i am using ''elevator bolts'' or another common name is table/ cabinet leveling bolt. it has a big flat head w/ a square shank just below the head. these are designed and used to level tables or cabinets. the square shank is to allow you to turn the bolt up/ down. they come in 1/4''x 20, perfect for our bolts running board. the flat head & square shank is like a carraige bolt but these are (i believe better). to make them fit you will have to belt sand/ grind down two straight sides off the big round head. then you can slid them in to place in the running board slots. they fit perfectly and a set of 12 cost my $1.00.
hope this helps
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
