well Hardy,Grigg is right on the money.Here we go with the money again.If the thing worked fine with the clutch fan and schroud.Replace the clutch fan or put a stock fan on.The schroud will take care of the cooling.If you go the electric fan expect to pay around $145.Fan $90-theromstat switch $35.Relay for switch $10.Check out the bone yards .Good luck
