| | | Forums66 Topics128,277 Posts1,058,441 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | With the stock fan and a shroud you sould be fine. If you have a higher than stock HP engine and A/C you may consider an electric one. Be sure to replace the clutch if it is bad. I assume you have a somewhat newer truck with the thermostatic clutch, the aluminum thing with fins between the fan and water pump. | | |
