7 members (57 Drifter, baldeagle, HandyAndy, gswbbc, tclederman, Cosmo, 1 invisible),
135
2
Mod | | | Forums66 Topics128,040 Posts1,055,478 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 93 Member | | Member Joined: Sep 2004 Posts: 93 | Hi all, my TH350 is leaking fluid at the speedometer cable housing. The housing is only held in place by a single bolt and washer on one side which is causing it to seat unevenly. Am I missing a part that would allow the housing to seal equally around it's perimeter? Also, since I'm not even using the speedometer cable could I just remove the housing and block it off? I hope this makes sense (it's early). TIA | | |
