| | | Forums66 Topics128,023 Posts1,055,366 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20709 05/26/2004 2:16 AM | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | Do you have a aftermarket floor shifter or the original column shift?,it sounds like someone has flipped the arms comming out of the trans. All you will have to do is reverse the arms from the way they are now and the problem should be solved.  | | |
