| | | Forums66 Topics128,021 Posts1,055,346 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | You should check the vacuum from both sources-
One is the manifold and the other is the carb. One is ported and the other isn't. For the Booster you'll probably want it from the manifold directly. If there is something else connected using a Tee, that shouldn't be a problem.
Whereever you get the vacuum to the booster from don't forget to put a filter in the line to prevent unburned fuel and crankcase gases from getting to the booster 'cause they'll ruin the diaphragm.
Autozone has those filters in their HELP product line with the other red blister pack things. Napa has them too.
'51 Chevy 1/2 ton w/'62 261, HEI, offy, fentons, dual carter/webbers, t-5 & 12 bolt posi
