Brake light switch is on the firewall underneath the brake pedal, when you step on it the lever on the switch moves.
Temp. Sender on the mechanical guages screws into the head near the firewall on the driverside of the engine. If the line on the temp. guage has been cut you'll have to replace the guage.
'51 Chevy 1/2 ton w/'62 261, HEI, offy, fentons, dual carter/webbers, t-5 & 12 bolt posi
