I'm looking to put disc brakes on the rear instead of using the original drums. Is there a simple (and cheap) way to put discs on the rear end or will I need to swap out the rear end? And if I go about swapping out the rear end does anyone know of one with a similar width and has disc brakes. Oh, this is a 1/2 ton if it makes any difference.
-- Ryan James
