7 members (Hotrod Lincoln, bobfake, GRNHydra, tclederman, Woodcmiami, Otto Skorzeny, 2-Ton),
43
2
Mod | | | Forums66 Topics128,091 Posts1,056,034 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Hey R.G.
Just went the same route with the tank in my 54. After bouncing lug nuts around inside to knock out the gunk and rust I got $44. kit from Eastwood.....save yourself some headaches...spring the $129.00 for a new tank from C/D and then you can concentrate on the other little things that are going to pop up on your truck. No rad. shop here in Fl. will boil out a tank and you'll be time and money ahead to bite the bullet and eliminate this major headache once and for all. My new tank is perfect....get a new sender for $29 too. Just my $.03.
Dave | | |
