| | | Forums66 Topics128,042 Posts1,055,522 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the whole 9 yards on the OD is in pdf\'s here and there's some do it yersef wiring info here passing gear [kickdown] switch is on the carb linkage and you can scoop something that'll work off any year junker that has OD - there's a harness specifically for it which is available from some of the vendors Bill | | |
